1 - 3 of 3 Posts
the bikes is a 2002 ducati monster 620. when i turn the ignition, the brake light is stuck on. the rear brake lever is properly adjusted, and when i removed the front brake censor and pressed it manually it tuned the brake light off. any ideas to fix this?
Thanks
I had that problem when I fitted pattern levers. Not sure if that's your problem. I traced it to a plastic pin that wasn't sliding properly and would stick. Bit of emery paper a Stanley knife and some lubricant has it working.
Sent from my iPhone using Motorcycle.com Free App
the rubber stopper that trips the front brake sensor on the perch had fallen out.
everything back to normal.
Thanks
1 - 3 of 3 Posts
