1 - 6 of 6 Posts
Hey all,
My brake light is constantly on.
I installed CRG levers 1 month ago and there was no problem then.
I removed the brake lever and the brake light is still on.
It is not the rear brake... but I suspect the Micro switch on the handle bar,
you know the little whitish rubber knobby that sticks out.
Anyone experience this as well? Is the switch screwed ( I have not removed it yet) I will disconnect the wiring there to see if it is it for sure but...
I am trying to be proactive here.
And if so what cost is a replacement (ball park)? And how long to get one?
Oh yeah I did a search but found nada
Any help is appreciated
2006 PS 1000LE
Hey all,
2006 PS 1000LE
Same thing happened to me when I put on the Pazzos. Does the light shut off with the lever removed? If yes, then the lever is catching the switch. If no, take the swith off and clean it with some contact cleaner. If that doesn't work, the micro switch http://issuu.com/ducatiomaha/docs/smart1000le_usa_06_ed_01 $78.99 at Ducati Omaha.
Brooksie thanks for your reply
Yes I removed the lever and it still stays on I will try the contact cleaner and se if it works.
Cheers
My problem was the switch was no longer seated tightly in the lever assembly. Check that first.
It should be on with the lever disconnected, it only goes off when the lever is in its resting position. (Pretty sure!?!)
Super glued it in place. Done.
I figure when it really fails I can drill the plastic to get it out.
Discussion Starter · #6 ·
Question on the Micro switch... There is a small clear rubber nipple with a hole in it. Isthere not a pin of some sort that is supposed to make contact with the lever to make the connection to the switch?
I am going to call the dealer once they open however I wanted to see if any one here knows.
Cheers
Tim
1 - 6 of 6 Posts
