I have M3 BMW car and have replaced the brake fluid every couple of years. Brake fluid absorbs moisture (water) and water is heavier than brake fluid, so despite the changes, the water still sat in the bottom of the calipers and chewed out some very expensive front brake calipers. Lesson learnt...
The issue is is that most bleed nipples are at the top of the caliper, and so the heavier water, that corrodes the cylinders and pistons, does not get displaced on a fluid change.
So I have decided to do fluid changes on my Ducati's, but I don't want the fk up I had with the M3.
The process I have at the moment is:- (and this includes clutch)
bleed new fluid through with slave cylinders in position
remove the slave and spray exposed pistons (not pads) with Inox
push pistons back in fully and chock wide open with timber
cable tie slaves up so that the bleed nipple is at the bottom most point and Let SIT overnight
bleed in this position
refit slaves and re-bleed
IS there a better way to do this to get rid of the water?
Some will say strip and replace, but with my Ducati's and Zane Laverda's as well I'm looking at a total of, including clutches, 103 pistons. Not a financially feasible exercise.
Regards, Greg
Regards, Greg
