Hi All,
I live in Turkey and spent s..load of time to get a problem fixed, haven't been successful so far.
I wanted to share it here, hoping someone could lead me in the right direction.
The problem is, the bike won't accelerate in any gear if more than throttle is applied more than 25% or maybe just 10%
The engine will just make a weird noise like its being strangled like fuel or air is not coming and ignition is not being made the way it should be and bike vibrates like hell.
When you turn of the throttle and start applying the throttle very very slowly, it won't do this till you reach a certain amount of throttle.
I have disabled all safety features (ABS, Traction etc) and the problem is still there.
Changes modes, no luck.
No ABS or DTC lights flash when this happens.
The bikes goes up till 130 kmh and through all gears without a hitch if you apply a very gentle amount of throttle (havent tried going above this)
But if you open up the throttle just a tad more, not even quarter of the throttle, it will do this regardless of the speed, even around 40kmh - 50kmh.
I got my air filter replaced, spark plugs replaced @ 25K
(bike is at 28K now )
Got the fuel injection system out took it to a bosch car service and got it cleaned at 25K
Got fuel from nowhere but shell.
The problem disappeared on its own for a while, no problems between 25.000Km - 27.800Km on the odometer.
Now it's around 28 but the problem is back and won't disappear.
I have the stock exhaust, bike is not giving any error codes (not now, not before)
When I start up the bike, the exup check sound can be heard clearly, but I have not removed the black aluminum cover on the stock exhaust and so haven't visually examined the movement of the exup valve.
Any recommendations will be greatly appreciated.
