So I've sent the 400SS's bodywork off for repair, fresh paint, and graphics. I would like to replace the screws and well-nuts that tie in the front fairing to the sides.
I have found 3/8" well-nuts and 1/2" well-nuts on amazon but i measured the ones I pulled off the bike at 14mm diameter at the fat end of the wellnut, where it bites in to the fairing. 5/8" is close to 15mm so that may work but what are you guys using for replacements?
Note: I found a set on Pro-Bolt but there's not a single well-nut in the photo so IDK if this is the right kit or maybe they just eliminate the well-nuts?
