The ST2 tacho became erratic some months ago and finally quit working altogether so after reading some of the threads posted here I pulled the dash out , cleaned and tightened the brass thingys on the back and cleaned all of the electrical connections. After I put it all back together and before I put the fairings back on I started it up. The dash worked as normal but the tacho was still dead. Too bad, I needed the bike for work on Monday so I put her back together and started it only to discover the dash is completely dead along with the tail light. I have now had it apart again, checked all of the connections and fuses and can't find any reason it won't play. Does anyone have a clue?
