1 - 10 of 10 Posts
Got home from a spirited ride and noticed my right pant leg and shoe splattered with some sort of oil... instected the bike and discovered oil spray all over the right lower engine case, rear set and exhaust head pipe. Then because I was now on the kickstand oil started to pool on the front wheel rim, there was also evidence of splatter all over the caliper and rotor.
Seems odd that I didnt notice this while I was riding. And I feel lucky nothing really bad happend:eek:
glad to read that the leaking fork oil did not cause any issues with the front brake pads ... that could have been not so much fun. :eek:
replacing the fork seals is not too difficult once you have the forks removed from the bike.
that will also be a great time to replace the stock fork oil. when i replaced the fork oil in my hyper, there was a big discrepency in the fluid level between forks.
1 - 10 of 10 Posts
