Recently took my termi's in to get ceramic coated and the shop ruined the rivet straps. Does anyone have a source for these?
Thanks in advance!
Thanks in advance!
The shop ceramic coated the straps and the end caps. To remove the ceramic they glass bead blasted everything... but it warped the straps and now they're all misshapen.How are they ruined? Scratched up? Cut?
If they’re scratched up, you could flip them so the mangled part isn’t visible or polish them out.
You could also probably get away with just throwing in steel rivets without the straps. Some aftermarket exhausts do this and I don’t see a structural issue if your termis aren’t carbon.
Curious which shop you used. I plan on having both my exhaust pipes and exhaust done soon. I will be most likely be sending mine to Jet-Hot in North Carolina.The shop ceramic coated the straps and the end caps. To remove the ceramic they glass bead blasted everything... but it warped the straps and now they're all misshapen.
Performance Coatings in Auburn, WA. The full story is I brought the pipes to them for ceramic for did not specify that the end caps and straps should not be coated. I assumed since they were stainless that it was obvious. Wrong. They coated the entire pipe, end caps / straps and all. When I went to pick them up I was.... not happy. He offered to redo them, but I would need to take them home, drill out the rivets, disassemble, and bring them back to have them redone... which I did... but the glass bead basically ruined the straps. I'm not too happy about that either honestly. I feel like they should have known better on both occasions... but it is what it is at this point and I just need to find a solution and move forward. The cones and headers look great for what it's worth.Curious which shop you used. I plan on having both my exhaust pipes and exhaust done soon. I will be most likely be sending mine to Jet-Hot in North Carolina.
I have the "For Racing Use Only" set for saleRecently took my termi's in to get ceramic coated and the shop ruined the rivet straps. Does anyone have a source for these?
Thanks in advance!
