1 - 7 of 7 Posts
Hi
I have done just over 5k miles on my st3. The last couple of times I have benn out for short rides, the bike feels like it has a bent rim when going around some corners. This doesn't happen all of the time, but when it does the bike feels vague and unsafe.
I have checked the front and rear bearings and the steering head and all seems fine.
The tyres are bridgestone bt020 and the rear has just hit the wear markers. It also has the dreaded flat spot in the centre.
I know the tyres are due for replacement but I just want to check that this could be the problem.
Any thoughts would be appreciated.
Cheers
New tires have cured more handling issues than I can imagine on my ST...both front (shudder during decel due to cupping) and rear (hunting/bouncing as if no rebound damping). It's usually the tires if you have no other changes you notice (leaky shock/forks). Sounds like they're due anyway. Replace 'em then see. :)
On or around the end of their life a lot of tyres do this. It is the "squared off" edges playing on the road
1 - 7 of 7 Posts
