Bi-Xenon projector installation in early ST headlight
3499 1
Some months ago I installed heavy headlight wiring with relays and a xenon high beam unit from DDM Tuning -
http://www.ddmtuning.com/Products/DDM-35W-55W-Single-Motorcycle-HID-Kit
This worked out very well, and I decided to install a bi-xenon on the other side so that I'd both get a bright low beam and a workable high beam flasher. I used the same Morimoto H1 that Chutrain used, since it fits really nicely -
http://www.theretrofitsource.com/product_info.php?products_id=3181
I don't have the headlight mounted in the bike yet, but the modification is complete and it was pretty easy so I thought I'd post a few pictures in case anyone else is thinking of trying this. I'd say the bi-xenon mod took about 2-1/2 hours, and you have to be able to fabricate one metal adapter plate. This plate (it's black in the attached photos) bolts to the Morimoto H1 projector, with each of the 4 bolts shimmed with 2 washers. Then my plate bolts to the OEM plate (matte silver in the attached photos), again with a few washers on each bolt so things line up nicely. I'm putting up front and back photos of the OEM and custom plates, and 5 photos of the assembly of the unit.
The shutter trigger on the bi-xenon wires to the high beam wires. That way, if I turn on the high beams or flash them, the high beam xenon bulb turns on and the high beam shutter on the bi-xenon moves out of the light's path.
The Morimoto H1 projector and ballast came from The Retrofit Source:
Bi-xenon: Morimoto Mini H1 5.0 - HID Projectors from The Retrofit Source Inc
This is the same projector Chutrain used - the site sells them in pairs for cars, but if you call you can buy a single projector and ballast. They offer a motorcycle kit, but the projector in the kit is slightly smaller in diameter than the H1 projector, and the H1 fits the early ST headlight extremely well.
1 - 2 of 2 Posts
1 - 2 of 2 Posts
