1 - 7 of 7 Posts
What is the best, including easy to use, software for my 999? And where is the best download site? I've used tunerpro, iaw, and guzzidiag on KTM and Laverda, and I now have o get access into the 999.
Need to display and reset fault codes, test componants (injectors, coils ect), copy the map to laptop, reset the service indicator. Don't know what else yet. It's also fitted with a PC3.
Regards, Greg
I've just downloaded a new version, but which Guzzi do I pick to give me the right ecu for the 999 (12/2002)?
its a 2003. if it has the original ecu it should be a 5.9m. later was 5.am. belter will be able to help you more than i can.
Just Visiting Your Planet
I've used IAWDiag on the 749. IAWDiag is the generic version of Guzzidiag. It works fine.
Discussion Starter · #6 ·
I found a list of ecu's somewhere, and there were no 59m's used on the Guzzi's, So I'll download the IAWDiag and see if it recognizes it. Thanks!
1 - 7 of 7 Posts
