1 - 7 of 7 Posts
If the price performance ratio is a relevant criteria: Which is the best allround rear shock absorber for the 748/916/996/998 series (still) available on the market?
Thanks a lot for your comments.
Super Moderator
Öhlins..
The reason is that they have been the best for a long time, which means that most (all) suspension service tech´s know them and how to dial and service them.
//amullo
Thanks a lot for your replies... :)
Which Öhlins rear shock would you recommend or is there just one version?
What other rear shocks are avaible for the 748/916/996/998 series?
As far as I know there seems to be Showa, White Power, Wilbers, Sachs-Boge, Öhlins, Bitubo and Penske. Anything else?
To be a little bit more precise about my question: The focus should be on a rear shock for a biposto that shall be driven on the road by "average joe".
I went for Ohlins because; They are proven, all suspension repair centres know them (and stock parts etc) and they are widely available, even on ebay etc - I bought mine used (but as new), got it serviced/overhauled for significantly less than a new one.
I've heard on this boad that the Penske are good but here (England) you don't see them so backup/knowledge is probably not there either.
You can choose an OEM version or a "racing" version with high and low hydraulic speed. For road only or road/track, OEM version is perfect...
But choose the correct shock for your bike, 748/916/996/998 fitting, but the hydraulics are not the same. A specilalist can change it and give you the perfect fitting to your bike. ;)
1 - 7 of 7 Posts
