1 - 7 of 7 Posts
There has got to be something out there to contain this under tail heat. Anyone find a solution that has proven effective?
Yes it's called a Suzuki ! Lol
Sorry man couldn't resist , ducati's are open roads only bro
They introduced an upgraded heat shield in 2013. I thought it was a recall where the older bikes were fitted but I could be wrong. One thing I wonder about whatever design heat shield used is if you could line it with a high temp shielding to reduce the amount of heat actually transmitted to the heat shield itself.
Something like this
https://www.pegasusautoracing.com/productdetails.asp?RecID=11221
If you want to make your own heat shield you should check this
This seems to be the only manufacturer that i found doing researches for my project which makes serious heat shields and not some kitchen ALU sheet :grin2:
Wrapping the pipe will retain more heat in the head/valve area I'm wondering?
(Read something about this in a Yamaha SR400 thread some time ago.Wrapping the pipe was not recommended.)
1 - 7 of 7 Posts
