Sigh
Am I reading this correctly that you are setting the belt tension on the horizontal cylinder at 1mm when it is cold? That seems really tight. I use a computer and a mic to set mine at 110hz as recommended in the service manual and I am sure the front belt is considerably looser than 1 mm even though I have not measured the gap after setting.LT's book says for the DS1000, use a 4mm key on the vertical cylinder and a 1mm feeler gauge on the horizontal. Anyone use this method?
From the WorkShop Manual of the 1000DS, 142Hz (+-5Hz).Am I reading this correctly that you are setting the belt tension on the horizontal cylinder at 1mm when it is cold? That seems really tight. I use a computer and a mic to set mine at 110hz as recommended in the service manual and I am sure the front belt is considerably looser than 1 mm even though I have not measured the gap after setting.
I borrowed a friend's harmonic tuning tool last time I did my bikes. I found it somewhat frustrating to use. You have to strum the belt just so, while holding the mic in the right spot and tilting your head left with your tongue sticking out toward the bike. Even if you do all that right, the readings jump all over the place at first. After setting the belts on all three bikes, I noticed that the 45deg rule seemed to apply on every cylinder. Hmmm. Maybe we should just put all the tools away and use the thumb and forefinger?
Me too. Also checked with the 5mm hex key. 5mm went, 6mm didn't.
I downloaded the gStrings chromatic tuner to my Droid4 and used it tonight setting the belts on my Multistrudel.Does anyone know of a good frequency measuring app for Android?
I downloaded this as well. As you say w/o a wire microphone it's a PITA, but I scrounged up an old hands free kit (before I used Bluetooth) and plugged it in my Droid. After experimenting with a rubber band, I generally got multiple readings within 1 Hz. Thanks!I downloaded the gStrings chromatic tuner to my Droid4 and used it tonight setting the belts on my Multistrudel.
https://play.google.com/store/apps/...trings&feature=nav_result#?t=W251bGwsMSwyLDNd
It worked pretty well, but I did get quite a few outlier readings. If I was very careful and plucked at just the right speed and with the right force, I could get some pretty consistent readings. It is a PITA to position the phone not having a little mic on a wire, but at a $249.99 savings over the Motoreva tool (Desmo Times Product 183 - Motoreva Belt Tensioner), I'll take my chances...
I'm with you Muzzmann........There is such a change between vertical and horizontal- hot and cold, that a single cold spec. makes no sense to me. Especially the low frequency that I don't find reproducible enough to trust. I ended up setting mine by "feel", monitoring between hot and cold, and adjusting as I thought appropriate. Once again by feel. I've been a Euro car tech for 40+ years and have been dealing with this question for almost that long. I always follow manufacturers procedures but this one makes no sense. I did use my approach as an excuse to add Speedymoto sprocket covers to make monitoring easier.......completely practical addition! I plan on developing a "happy" hot frequency for each cylinder......they will be different. In the mean time, I can see the belts and bearings every time I step on and off the bike. For the cost and time involved I plan on changing belts every 2 year/10k miles anyway. Bearings every other time. I'm having to dig to find maintenance to do on this lovely lady other than cleaning. Not at all like back when you'd figure 1/1 maintenance to ride time. Gotta love it!!I just eyeball em and check them when its hot to make sure they are not too tight ......never an issue....
Having said that I am working on developing a permanent solution to this .....stay tuned
Muzz
