I did a track day yesterday and about halfway through the day I noticed that the bolts on my vertical cylinder belt cover were coming out and one was gone. Should I loctite them when I put 'em back in? Monster 1100 - must have been built on a Friday.
I don't see anything wrong with a little loctite on them. I put the blue stuff on every bolt I take off.
This became a habit after I had one of the bolts in the clutch pressure plate on my 748 back out mid way through a track day. I needed a clutch pack and basket and it came the day before the track day. In my haste to throw everything together I didn't tighten them enough.
I noticed whenever you see torque specs it always says to grease the bolts. I would think that that would make them back out easier. Does it just keep them from seizing up and if they are properly torqued they won't come loose?
