21 - 23 of 23 Posts
1000ss with belts removed and vertical inlet cam on the nose of the inlet will get a bent valve and cracked guide if you turn it over fast in second gear. hopefully only do it once.
I wanted to close the loop about CA Cycleworks (Chris), I got the original order but never a confirmation of shipment. Likely overwhelmed with online orders. About 4 days ago I got the belts in the mail with a red twizzler and invoice record. Thank you Chris!
‘07 ST3s
I got OEM belts from DucatiMondo in UK after our local dealer failed to return my call after a couple days , cost less than local arrived in less than 10 days
21 - 23 of 23 Posts
