Figured I'd present the problem here as well as contact Bazzaz for help.
Got my Bazzaz in the mail today and installed it per the instructions. Went to turn the bike on before putting everything back together and I get nothing but the bike turning over.
So the obvious troubleshooting started.... checked every connection 3 times over, cleaned the grounding locations, checked all fuses (just in case), made sure no fuel lines were pinched and the list goes on.
Long story short the bike will run if I
-connect the bazzaz to the front cylinder injector and leave the rear alone but leave bazzaz connected to all other connections
-don't connect bazzaz to either cylinder, leaving it connected in all other locations
-Installing the bazzaz injector connections in reverse will make the bike run but it obviously isn't right.... you can hear that it's not correct.
Anyone have any ideas?
