Yes, you can plug a Battery Tender into the accessory socket. I have a 2002 ST4s, but I don't think anything has changed (other than higher rated wiring and fuse) with the accessory socket on the 2004 ST3. I've been using the socket for my Battery Tender for years.Tank said:I have a 2004 Ducati St3, can I plug a Battery Tender into the accessory outlet? If so where do i get an adapter to fit the outlet? Thanks everyone for your help.
I got my BMW plug adapter from a local BMW motorcycle dealer. It's a standard over-the-counter part. If you can't find a dealer, or for some reason they don't have one, you can get the part "PL/SAE CABLE - PAC-008" from Powerlet online...
http://www.powerletproducts.com/products/cables.php
