1 - 2 of 2 Posts
The storage facility where I keep my track bikes doesn't have power so I carry 2 batteries back & forth to keep them on Tenders when not at the track. That sucks....
I want to consolidate and have just ONE battery that I can use for both bikes....
My 1999/2000 Mille has a YUSA MFYTX14-BS battery (still stock) that puts out 14 amps and 200 CCA - from the various battery websites, it can also use one that puts out 12 amps with 180 CCA.
I was looking to buy the AMG YTZ7S battery for my 1999 748.... It's a good size/weight and even with only 130 CCA, it seems to be popular with 996 Ducs - so it actually can power things up on a full liter twin... Am I crazy to use the YTZ7S on the Mille or can I use a 12 amp 180 CCA Mille Battery on the 748?
I'll check the terminal posts but I believe that they will work even with the heavy duty Duc cables from Moto Wheels - I'll just need to get creative with the Duc's battery holder...
Super Moderator
As long as it fits, you should be ok.
I run a Yuasa 7amp battery on my 748SP that has a higher compression then a "stock" 748, so turn-over shouldn´t be a problem. Atleast not on the 748. The Mille i have no idea on.
//amullo
1 - 2 of 2 Posts
