1 - 12 of 12 Posts
Hi All,
I am coming from a BMW which requires a special battery charger/tender to maintain the battery. Does a 2016 Multistrada require the ducati tender/charger or can I use a battery tender Junior?
Thanks in advance.
I'm not 100% on the Multi but if there is a battery tender connection under the seat it's bound to be the Ducati specific one like the rest. You can buy a Ducati to SAE adapter cable on Amazon that will allow you to use a Battery Tender/Battery Tender Junior though
[ame]http://www.amazon.com/Tecmate-OptiMATE-CABLE-Adapter-DUCATI/dp/B00HHPBF46/ref=sr_1_1?ie=UTF8&qid=1546399442&sr=8-1&keywords=ducati+to+sae[/ame]
The Ducati dealer here in Sydney installs the Junior by default. So I’d be quite confident in stating that no special Ducati one is needed.
I'm using a BT bought at Costco, on my 2016 Multi PP. The terminal was installed at the dealership. It work as intended.
Sent from my SM-G950U using Tapatalk
i use the standard battery tender. more durable and you can use it in other bikes too. just add the included pigtail by connecting it directly to the battery.
You can buy more pigtails for your other bikes.
The mts unlike the monster battery is easily accessed through the seat.
Good luck
Hi All,
Thanks in advance.
I've used the Tender Jr for all my bikes, including the MTSE, and have not had any issues.
http://www.amazon.com/Tecmate-OptiM...&qid=1546399442&sr=8-1&keywords=ducati+to+sae
wondering if the multi has this ducati-specific connection. i already added a pigtail to the battery, but curious anyway.
My '13 came from the factory with that connection.
this is what I have for my mts and ktm. battery is easy to access. just remove the seats
I also have the optimate for
my monster 12. battery is hard to access thus I connected this to my monsters ducati plug under the seat
Sent from my SM-N950F using Tapatalk
1 - 12 of 12 Posts
