1 - 6 of 6 Posts
I own several trickle chargers that work differently so I did some research. I found it's possible for a "trickle charger" to damage your battery. Here are my conclusions:
Battery Tender Junior
- Charges at about 14.4 volts then shuts itself off until battery voltage drops
- Conclusion: safe
Cheap Amazon trickle charger (MOTOPOWER MP00205A 12V 800mA Fully Automatic Battery Charger/Maintainer) $13.50
- Charges at about 14.2 volts then backs down to 13.2 volts
- Conclusion: safe and maintains battery at full charge without inflicting damage at least
according to this article - Trickle Chargers, Float Chargers, Self Discharge Rates and How it Works Together
NOCO Genius G750 6V/12V 750mA Advanced Battery Trickle Charger Maintainer $29.95
- Charges at a continuous 14.4 volts contrary to the manufacturers claims
- Conclusion: Charge rate too close to the overcharging threshold; unsafe to leave on charger for long periods
Excel Addict
2001 900SSie
Not correct - Just checked the voltage of this model that has been on my bike for about 3 days, so well into maintenance mode.
Sitting at 12.39 Vdc.
I am very happy with that having been involved with lead acid batteries for many years, well decades.
I have 4 battery chargers that I use at any given time.
I have a YUASA charger that is essentially a Battery Tender Jr. I use it for keeping batteries in my cars that don't get driven topped up. It would be fine for any standard lead acid battery. I found it unsuitable for AGMs after frying 2 of them with it.
I have a Schumacher battery charger from Auto Zone. Had it for decades. I use it for my cars batteries when they go dead because a family member left the interior light on, or some other equally dumb thing. I don't use it for any of my bike batteries.
I have a Tec-Mate smart charger that I use for my bikes with AGM batteries installed. It has the circuitry to charge and go into a maintenance mode. I've used it for a couple of winters now and it does the trick with my AGMs. No fried batteries since getting it. It charges 2 batteries at a time so is ideal for having multiple bikes. Two bikes stay on it all winter long without issue.
I have a Shorai charger for my Shorai battery. I have it because it has the cell balancing circuitry needed for maintaining a Lithium battery. It was not super expensive, less than my Tec-Mate by a bunch.
As for flooded cell, lead acid batteries, I don't use them in my bikes anymore. My opinion is, use the appropriate charger for the type battery you have and your battery will be fine.....sean
I've run 2 Battery Tenders for years with no problems. Used also on my Shorai which is 7 years old.
Paul 03 ST4s, 15 675RX, 96 ZX11, 76 KZ900LTD B-1, 72 SL125
A comment on your "not correct" statement. What's happened is my Noco Genius charger has developed a defect and that's why it charges continuously at 14.4 volts. This could likely happen to any charger. The circuit responsible for cutting voltage has failed. I have one Battery Tender that works as designed and another that acquired a defect and never goes to standby mode. That defect cost me a couple of car batteries ($250) before I figured it out.
The takeaway is don't trust your charger to work as designed. Use a voltmeter to make sure any charger either moderates it's voltage or cuts it entirely once the battery has achieved full charge.
- Conclusion: safe
This is maybe the perfect illustration of why these discussions are so difficult.
There is massive variability between chargers- even between the same chargers from the same manufacturers!
I have 4 Battery Tenders here.
None of them charge at the same voltage.
Our CTEK and Tec-Mate chargers are much better about variability.
Suggestion- verify charge voltage with a multi-meter.
1 - 6 of 6 Posts
