1 - 2 of 2 Posts
Anyone using a Barnett Clutch Kit # 306-25-40002 with a slipper clutch and aluminum basket? I have a MotoWheels drop in slipper. Looks like the stack height will be the same, but I'm concerned with Barnett's combo of a damper spring and seat/thick drive plate as opposed to the two curved plates in the Surflex that I used last time.
Will it work?
TIA
Steve
grand poobah
slipper
Hi Steve, I believe it will fit as expected but the issue will be that the Barnett set is organic and not the sintered material. I believe the organic friction plates will be quite grabby in a slipper configuration, add to this the deletion of the curved plates and clutch actuation will be pretty harsh. No reason not to try it though. I do not believe it will harm anything. Best Wishes Brad.
1 - 2 of 2 Posts
