Anodized would be my guess.Do you think a stock swingarm is painted or powder coated?
+1anodized would be my guess.
+3
So since the stock swingarm is anodized then the proper way to "revert it back" to an aluminum look (to remove the anodizing) is to use NaOH. What kind of shops deal with NaOH?...no, it's not painted or powdercoated. It is anodized.
Quick search on google shows this supplierSo since the stock swingarm is anodized then the proper way to "revert it back" to an aluminum look (to remove the anodizing) is to use NaOH. What kind of shops deal with NaOH?...
I think this is pretty solid advice. It really wouldn't take much to sand it down to the bare skin, again.just get out the sandpaper! or take it to a sandblaster if you don't want to do it yourself - cheap and fast and easy - use whatever grit you need to get the finish you want...
Still lookin' to save some weight Sputz?...How hard it would be to tear the swingarm's black coating making it look aluminum? Would it have to be done with a sandpaper or there is a more efficient way to do it?
