Just wanted to post my experiences with the Dual Electronics XGPS160 GPS unit and the Race Chrono Pro App.
I was really surprised at how awesome the App is. And the Dual Electronics XGPS160 is one of the more affordable high frequency GPS pucks which you will need for the precision.
The GPS puck is around $150.00 and the full App was 15.00 I think- not sure if there is a free version anymore.
I highly recommend trying this setup.
Visually it plots your path on the track and your line is color coded to show when you are accelerating, maintaining or decelerating. The track lines are extremely precise and it lays it out on a google view of the track. It automatically records lap times, and also splits provided that splits been marked for that track. If you have a solid mount for your phone it seems you can use the phone's accelerometers to track lean angle and g's as well if that's important.
I was able to compare the results to an integrated system that an instructor was using recently that cost hundreds more than this set up and it was spot on for timing.
It seems like it would be good for any kind of trip you may be on, but I only have experience with it at a track.
Anyway, I just wanted to throw it out there-- I was doing a lot of research on this before buying and decided to try this and was pleasantly surprised.
-Md
I used RaceChrono years ago when I was racing, in combination with a real cheap (as in $30 AUD) 10Hz GPS receiver - definitely not good enough to use the default 1Hz receiver in most phones.
Supply and demand is a killer. When I purchased mine, you could pick from around a dozen devices with this spec around the same price, but a quick look around now shows that these things are at a premium.
RaceChrono is a great bit of kit.
