Still needs a life.
I had troubles starting my 02-ST4s when I first got it. Ducati Seattle tracked the problem down to an aftermarket sidestand cutout switch the previous owner had installed. Removing the device removed the problem.
Moral of the story: if you are going to install a sidestand cutout switch, make sure you do it correctly or future problems could entail.
