1 - 2 of 2 Posts
$500 + shipping
Size XL
**** Arai Corse Vector / Ducati*
This is in mint condition! Only wore a few times!
Designed exclusively by Arai for Ducati.
Simply the best of the best !! Period !*
DUCATI CORSE HELMET SHELL*
The Corsair-V shell offers the ultimate combination between strength, lightness and flexibility.*
The main material of the outer shell is Arai’s exclusive Super Fiber, now with increased fiber density. The shell rigidity has also been increased after extensive experiments with different fiber thicknesses, different fiber after treatment procedures and different combinations of resins.*
Peripherally Belted SNC Shell: a belt laid peripherally on the top of the eye-opening of the shell increases the rigidity of the shell even further. This belt construction was devised during F-1 helmet development to reinforce the forehead area of the shell.*
DUCATI CORSE HELMET INTERIOR*
Both cheek pads and the neck roll can be removed in seconds thanks to the advanced Emergency Release System. Rescue and medical workers can easily remove the newly designed removable neck roll and the cheek pads by just pulling the pad release tabs. This offers extra room within the helmet, making removal of the helmet much easier and minimizing the risk of additional injury.*
The Corsair-V benefits from a wider visor aperture that offers more view through the bends, giving you every time that split-second advantage accelerating out of corners. And especially in racing, every advantage is important. Ridges along the upper edge of the aperture offer a smooth transition between shield and shell, reducing wind noise and impact in case of an accident, because there is less chance that the visor is ripped away from the holders.*
A clear CE-approved thermoformed visor that is scratch proof and anti fog is included. Additional visors are sold separately.*
DUCATI CORSE HELMET FEATURES*
Air Wing that reduces drag, turbulence and buffeting resulting in more comfort and additional top speed.Very lightweight.*
Three external shell sizes.*
Neck protection.*
Removable nose deflector.*
Airflow Spoiler Type 5 directs the airflow around the bottom edge.Together with the new Power Intake Shutter chin vent and the FFS (Free Flow System) aerodynamics around the bottom are optimized.*
An additional air intake between the front and rear intake in the diffuser and large toggles.*
The Air-In ports help accelerate air out the back, increasing airflow without increasing the size of the holes in the shell.*
This new diffuser guides more air in and more air out, using aero dynamic design instead of simply making bigger holes or larger, and therefore noisier and less aero dynamic vents.*
The reshaped Delta Duct 5 air intake increases air flow and lowers noise levels.Thanks to this new ventilation system, interior temperatures are lowered much faster than with previous versions.*
Arai has Redesigned and integrated high-efficiency ventilation system. Air taken from the visor brow vents is directed to the temple area through special inner duct air channels.*
The multiplier effect of the Side Exhaust Duct 3 and the new NE (‘’Neck Exhaust’’) Nozzle 2 increases the ventilation effect at the lower part of the helmet.*
Fresh air is redirected from the brow vent air across the temples and to the ears, which radiate much body heat, and is then efficiently exhausted out via the newly designed side cowls.*
Penetration tested shell features Hyper Rib ridge lines around the bottom that prevent compressing of the shell. Sleek, aerodynamic Side Exhaust Duct-3 integrated into the shell regulate air stream and prevent buffeting at speed.*
1 - 2 of 2 Posts
