Anyone tried the MF battery in place of YB16
1130 4
I recently bought a new YB16AL-A2, but I was so tempted to try the newer MF battery? I think it is a YT12B-BS. This is a lot smaller than the older type battery so how would you "pad" the older type battery box to take the smaller battery?
Thanks
Richard
I've been using the newer, smaller battery for a few years in my SS, replacing it this spring "just to be sure" it would continue working OK this season.
What I noticed on my modified engine (944, 10.5:1 CR) is that the battery will spin the engine to a compression stroke, hesitate a second, then spin the engine and start. I thought it might be the battery getting on in years, but the new one does the same thing. It has always started.
OBTW, the weight savings is pretty good, 1# from my measurements.
The Yuasa battery number for the MF battery is:
YT12B-BS
It is quite a bit smaller than the other battery, hence my asking how do you pad it to fit?
