41 - 43 of 43 Posts
I have the same issue... what I do is torque the outside bolt correctly and then use an allen wrench to manually push it just a bit more to 'calibrate the fingers' a bit. Then I torque the inside left bolt manually... then redo the outside and inside bolts. I'm sure it's pretty inaccurate but hopefully better than guessing.
Thanks. Yes this is my method as well. I would imagine it is accurate enough. Just ordered up 8 of those bolts from Fastenal. Shipping was more than the bolts but still all in less than buying 2 from the dealer. And I am sure given their size I will use them in the future on other machines.
Yes, remove the wheel speed sensor. Takes 1 minute. I have to use an extension for the socket to clear my Clearwater light.
41 - 43 of 43 Posts
