1 - 19 of 19 Posts
stripped inserts in the tank and/or the airbox are not a big deal ... very easy to fix yourself.
  • get some good quality epoxy
  • take the insert out of the plastic
  • clean the hole in the plastic out (remove any plastic burrs/dust)
  • clean the insert "barbs" out with a toothbrush or wire brush
  • mix epoxy and fill hole in plastic about 2/3 full
  • screw bolt into the insert (place some grease on the end of the bolt, before screwing into insert, so epoxy will not stick to bolt)
  • smear some epoxy on the insert and place into the hole
  • tap the bolt with a hammer/mallet to seat the insert fully into the hole
  • straighten if required
  • let epoxy cure
  • remove bolt
  • install airbox lid
the above process is what the mechanics at the ducati factory who maintain the press bikes do to deal with stripped inserts. works great, fast, and easy to do.
i have done the above on three inserts (two in airbox, one on fuel tank).
ciao,
johnc
I sheared off a bolt in the airbox with a 3 inch allen key... that's pretty ridiculous, if you ask me. I was taking the airbox off to put on the Beast kit, so I haven't tried to cover it under warranty.
They installed them with an f*%king impact gun:mad:...it if really frustrating when a tiny brass fastener that is anchored in plastic takes that much effort to break loose. I was in disbelief when I took mine off... had two of the six strip and used a screwdriver to pry open the lid after that, then pressed the studs back in and installed with correct torque, no issues.
Very Frustrating....Just a thought here ...I haven't had any issues with them yet...Would it help if you iced the area around the inserts to stiffen up the plastic a bit before removal? If you guys are working at 80 90 100 degrees ambiant temp in your garage would that be a factor?? Even if it saved just one or two of them..Yea over tight is over tight ...What brand name and type of epoxy would yous reccommend ? so I can have some on hand???
Discussion Starter · #10 ·
I talked to my local dealer and Ducati North America about it, it should be covered. The worst part is that I have to take my bike in all stitched up to have them replace it.
what is happening is simple chemical reaction/corrosion ... the bolts are one alloy, and the inserts are brass. to avoid this happening in the future, i used a small amount of loctite anti-seize.
Duc ... Duc ... GOOSE!
Mine weren't stripped, but they were gorilla tight and spun the captured nut when I went to remove the airbox lid. This directly led to me breaking out the Dremel and surgically removing the lid. A complete waste of an airbox because some jackass overtightened the bolts. :(
Damn it! I went to try to do the airbox mod and this is my problem now!!! I read that someone had to pry the lid off with a screwdriver. I would try this but it is the two bolts at the rear of the airbox closest to the tail section. I can't really get to them without removing the tank completely. Any suggestions?!?!? Please help, if you can.
My warranty has been up for a little while, so I guess that I can't get the dealer to replace it.
Thanks for the reply, Dave. But I'm already on the preorder list and I would like a solution that I can do immediately and inexpensively until I get the tank and stacks later on. I do want to ride my bike before then.
Ok, then seriously, use a screw driver to pry up on the cover WHILE you unscrew the screws. The leverage from the cover lifting up on the screws as they are turning out should get you going.
Dave
Thanks, Dave. I will try that!
Got it! Screwdriver trick didn't work. Thanks anyways though. I had to cut the edge of the plastic on the lid from the bolts to the edge with a sheetrock knife. It worked and the bolts are still in the airbox. I just have to wedge the lid under them first then install the other bolts after. Luckily they were on the same side.
1 - 19 of 19 Posts
