Hello all . Having had a hot start problem as regards to turning over but not fireing up and then running very rough and rich, but on the button cold start ,i have nailed it down to the water/air temp sensor on the inlet rocker cover on the horizontal this monitors engine temp as regards to fueling hot and cold, my old one was giving signals to ecu the same cold as hot so rich mixture cold thats right, but the same as hot so rich mixture when hot hence the problem. new one fitted problem solved, cross reference part no BOSCH 0280130026 cheaper than ducati , i hope this helps john.
