1 - 2 of 2 Posts
So I sold my full Termi system from my Monster S4R including the DP ECU. New owner says his bike won't start with the ECU installed. I always thought DP ECU's were always unlocked but after some reading it seems like no. Is there any way to reset it to work with his S4R? Thanks guys.
any new ecu is virgin, but if it is put into a bike AND a key coding procedure is run it is coded to that bike's immo. most never did key coding procedures with the dp ecu, so they could be swapped.
is it going into a s4r desmoquattro or testastretta? i've seen people mix that up before.
guzzidiag have an eeprom reader for the 5am i think, maybe with that you can virginise the immo again. never looked at it, probably should.
1 - 2 of 2 Posts
