So the turn signal cutouts are already done when they ship the mini-halves?I'll be using a Sharkskinz SL style solo seat panel with a Corbin seat and bum pad along with a set of the Ducati Kaemna mini fairing panels on my bike Rex.
As far as drilling out the mounting holes on the mini fairing panels,the hole placements are clearly marked so it's not really all that big of a deal. Just need a Dremel tool and a good steel cutting bit and you're good to go.
You might be over thinking the attachment of the mini fairing panels at the rear of the panels Rex. When I bought mine I inquired about that and was informed that the 3 mounting points on the panels were considered by Ducati Kaemna to be more than enough secure connection to provide the necessary support for the panels.
What they also suggested was to add a strip of stick-on foam insulation used for sealing door frames to the back side of the panel along the upper edge at the rear of the panel to keep it from contacting the frame and scratching the paint. I marked that out with red lines in the pic below.
Now that I see what you pointed out ... the mounting holes ... you're right ... it looks to be a much simpler task to drill them accurately.
Nice pics! Thanks! Really encouraging!!
