1 - 7 of 7 Posts
I had both of my seats off of my 2014, when I went to put them back on this hunk of foam/rubber fell to the floor. I can't see any obvious place where it came from.
Help?
North Carolina, USA
I'm probably remembering wrong, but I recall at one time a tech bulletin or something about a piece of foam/rubber that was to fit under the pilots seat to keep it from flexing. It was supposed to keep pressure off of something underneath, maybe the ABS unit?
That's all I got... :|
Reactions: nikwax
Smut peddler
I haven't stayed at a holiday Inn express in awhile, but my best guess is that it came from the motorcycle. The good news is that when you work on a bike and you have extra parts and it still runs, you've been promoted from mechanic to engineer.
Discussion Starter · #6 ·
It is glued to the seat bottom in line with the banjo fitting on the abs pump. See the indention that looks like a bolt head.
Cheers
Perfect, thanks!!
And the the bike is lighter also, win win with fingers crossed.........the worst thing i hate is when i drop a screw or small part or an ellen key into the depths of the bike and never to be found again.
1 - 7 of 7 Posts
