1 - 20 of 33 Posts
Hi, just picked up a 95 900ss after i sold my SC1K ....have read and learnt a fair bit about them from this forum.
Senior Italophile
:yeah:Nice new to you bike! :cool: What grips are those? they look nice and thin.
Resident Raggamuffin
i like it, and so oem! beautiful bike.
good for you, and congrats.
I have a button.. BITCHES!
That's a damn nice bike. I REALLY like it. BUT.......now we gotta put up with your ass in ths Supersport forum. There goes the freakin neighborhood.:D
By the way, your front brake rotor has a gnarly ass line running through it. Get that shit checked out.
Discussion Starter #9
you know i'm saving up to go back to the states on holidays again , you are on my list of people to vist :p
Corks, you damn turncoat...and after all that work and modding, to dump your Sport.
Nice looking SS, though...at least you didn't get one of those fugly Terblanche SSs.
Discussion Starter #12
Just out of curiosity what differences are you finding between the SS and SC?
The sale of the SC was caused by fiancial issues so not much i could do about that.
The 900ss motor as expected is ruffer than the 1000DS motor - its slower to spin up (yet im not sure i would go lightened flywheel), less smooth especially at low rpm (the DS would spin down and up as low as 2k rpm, you can feel the 900ss is not really smooth until 3k rpm, the DS is more torquey and powerfull). The gear box on the SC1k was very nice and smoother than the 900ss. On my SC1k with the 748 calipers, the brakes felt better. The SC1k felt flickier and flightier whereas the 900ss feels more stable
So I sounds like I'm bagging the 900ss, but these are honest observations.
Having said that, I'm enjoying the 900ss took it out on a country run the other other day and had a ball and i certainly don't feel short-changed in the fun department.
hope all that makes sense :)
Discussion Starter #13 (Edited)
couple of questions
I have fitted the a MPL Tuning clutch slave cylinder as the old one was shagged - feels alot nicer but the bike is now a prick to get into neutral at a stop - just flicks between 1s and 2nd until eventually it won''t shift out of 1st.
I understand that the larger slave cylinder can exacerbate this problem - is there anything i can do about it? I'm getting some Pazzo lever fitted will they help and i understand there is some adjustment in that screw in the brake assembly (Not sure of it proper name but the one that is araldited over)
And can somebody tell me please the range of adjustments on both the forks and shock (compression and rebound) and also what the factory settings were.
Make it 3 questions - how do i pull the stock bar end plugs out of the clipons - doesnt seem to be any screws holding them in so it is it a matter of grip and yank ???
cheers Dave
Discussion Starter #14
stuff done so far
as mentioned low kays :)Wasnt to struck on the carbon fibre dash - dont mind it now and the weave matches (nice)
cheesey but some of the most comfy grips i've ever used (apparently they cry if you squeeze them too hard tho:) PS that sticky tape covering the light on/off switch looks crap - did there used to a plastic cover there instead??
gutted stock pipes for a nice sound - not as loud as the sc1k was
already had a 14t front sprocket fitted and i picked up a s/h but in good nick 38t rear
oil cooler guard off a local company
well worth the money
replaced the shagged stock one
be rattly, be loud
better make it look pretty then
bit more functional - braided brake and clutch lines
cheers Dave
take the cap off the other end of the clip on and then stick a rod or dowel into the bar and tap it out from the inside with a mallet.
(nice bike btw.)
Discussion Starter #16 (Edited)
these
plus this
make for much nicer shifting and i can now get into neutral much easier at standstill
:D
big thanks to waspsie for helping put them on and a gratuitous random pic
Beautiful Bike
and it definitely stands out in the last picture amongst those dark bikes. Gorgeous!!! My 95 does not have the third gage (temp)?? Where to get? Do you think important to have temp or voltage as the third gage?
Discussion Starter #18
interesting thaat you say your 95 doesnt have a oil temp gauge , my understanding was from 95 onwards they had the extra gauge - maybe yours is a late 94 ????
Discussion Starter #19
new bling and fitment
first up some wavy rotors bought locally , compared to the stock rotors, they weight 442 grams less.
and also locally picked up a s/h ohlins shock
So headed up to waspie today to get them fitted - greg and tez gracious as always - coffee and biscuits non-stop:)
rotors first and they fitted with zero probs what so ever both on the rims and into the calipers
and then on to shockie - fitted quite easily with the right tools and greg doing most of the work - fitted it first checked everything pulled it out and adjusted up the preload (to give around 35mm of sag) and wound the height adjuster out 3mm to give ruffly 10mm extra (ohlins is slightly longer than showa even with ride height adjuster wound in) length/ride-height, and then refitted
all ready to rock - both brakes and shockie feel better, but will ride it abit more before giving a better description
Nice bike! I think your pics convinced me to put the Agip stickers on mine. What's the story on the Marchesini stickers on the wheels? I thought the three-spoke SS wheels were made by Brembo (though I believe they are now owned by the same company).
1 - 20 of 33 Posts
