1 - 8 of 8 Posts
The fuel light and "low fuel" dash warnings went off. I filled the beauty up as she asked. I noticed that the fuel light went off but the "low fuel" dash message is still flashing. What gives?
I searched the forums quickly but couldnt find this scenario...
Right... that would help...
Its an 05 800SS... she has an indicator light and the digital dash says "low fuel"... the light went off but the digital warning is still flashing...
Des... I saw your post... its the fact that the damn light is out but the dig is on thats f'd up... might just try your fix eventually...
Try this:
Disconnect the battery. Wait ten minutes. Re-connect the battery.
Sometimes this'll clear the fault indication. But there's no guarantee it won't happen the next time you need gas. If it does, then I'd bring it back to the dealer you bought it from.
Discussion Starter #8
thanks felix i'll give it a try. shes used with no warranty so if it doesnt work i'll have to keep investigating...
1 - 8 of 8 Posts
