Been through a couple Monsters, a 999S and a Hyper, soon I will have a Nicky Hayden 848 in my garage.
What are the must-have mods for the bike? The dealer will have a -1 front sprocket installed, and as time goes on I will of course get some new levers, rearsets and things like that, plus a steering damper.
My main question, is exhaust.
The one thing that I hate about Ducs is the cost of exhaust, because they almost always require an expensive ECU in order to disable the O2 sensors, so that you can spend another $350 on a Power Commander and another $250 on custom map. By the time you are done, a slipon ends up costing you two freakin grand. LOL
So, what are my best options? Stick with Termi? Can I get a Termi slipon now, and then add the header pipes later to convert it to a full system?
Does the new Power Commander V have a means of fooling the stock ECU and O2 sensors, so that I can get any slipon that I want and have my guy tune it on a dyno?
What's the best bang for the buck, and does a full system offer enough HP over a slipon to justify the doubling of the cost?
Thanks!
Thanks!
