It is very close. That's normal. Make sure that you still have the brass spacers in the gasket that fit between the cover and the casing. It will look very close but as long as it actually doesn't touch you'll be okay. Remember, the spring keepers do not move out with the pressure plate, but stay put in the position they are screwed to the hub. The pressure plate moves out and in with the compression of the springs.
