Few pictures and a couple questions. See if anyone can help. Just want to remove the canister and associated plumbing. I had a 95' 900 SS/SP, and it was configured differently. This one (98' FE) has some additional plumbing with an object about half way to the canister that I can't identify (see photos). Chances are that the owner of the 95' I bought did some work to eliminate this before I bought it, so I never saw it configured correctly... Anyway, bottom line, I'd just like some advice on how to cap the holes in the intake tubes (pictured) once I pull the hose (there's a mating screw with a small air hole it in... that needs to be capped) and where to route the line that comes from the gas tank once I dump all the superfluous plumbing. The check valve coming off the gas tank may have failed too, but I won't know until I get all of the plumbing disconnected from it. Thanks.
Pix are (hopefully) posted in order from gas tank to canister.
Cheers
Cheers
