So I know many have had issues with their first-gen hyper dash / gauges / instrument panel, and I did some searching and didn't find anything on this problem (although the solution may be the same).
Picked up a near-new 1100s w/ 1700 miles w/ 1 issue - the dash works fine when the key is on and the engine is off, but once the engine turns on, most of the "marks" on the dash go away and I can barley read the revs, speed, miles, time, etc. But then i turn the engine off, and leave the key on, the dash works perfectly again (until i turn engine on). Will try to post vid tonight.
So has anyone had this specific problem? I've seen threads where people cant read dash but figured that would be due to issues w/ the screen itself going bad, which doesn't appear to the be problem here given it works perfectly when the engine is off.
Given it was like this when i bought it from dealer, they are going to give me a new OEM dash to install, but am worried that may not fix it.
Thoughts? Also, how easy is the dash / instrument panel to replace?
