1 - 3 of 3 Posts
And finally the solution to set the alarm pin. Tried the red key...nothing, tried the solution with the tank button/red switch solution...nothing.
Check under the seat and find the 15amp fuse for navigator/Alarm. Remove the fuse and turn bike on. Then touch the fuse to it's contacts once for 1, twice for 2 etc. This is the only way to input code fast enough!
1 - 3 of 3 Posts
