1 - 3 of 3 Posts
Dan look for a shop that sells KN filters, The Ducati filters should be available. The oil filter has a nut on the top so removal is a breeze. The air filter is the washable type. Much better than the paper ones. If you can't find it locally you can order it on line. You will need to get the 2 rings. One for the oil drain plug and the other for the screen. Good luck.
1 - 3 of 3 Posts
