Hi. When I took off the air intakes to open them up, I notice what appears to be some sort of breather hole that is near the front and about 1.5 inches in diameter - anybody know what this is and if it matters if water gets in there?
Also, there is what appears to be a drain tube at the bottom of the right side of the airbox that connects to the transmission case - does anybody know what this is and whther water will screw something up?
I'm worried about water getting into the crankcase or transmission case. What say?
