I dropped in the factory pro kit on my 1997 900ss and tuned to kit specs. Really it was just the new needles, springs, and emulsion tubes. Before the kit, the engine was a tad rich. So I adjusted the floats to the spec 14mm and went 3 down on the needle. Fired fine but was waay lean. Went to adjust the air/fuel screw. (the screw was pretty gnarly to start off with) and wouldn't budge.
So, I dropped the bowls and raised the floats by 2mm each. and brought the needle position to 5.
Fired it up. No better that the first settings.
What are my options here? Drill out the brass screws?
Thanks!
Thanks!
