Hi guys.Wanted to install my brand new sp air filter under my 2012 pikes peak today.
Took off the fairings, ready to unscrew the 3 screws keeping the air duct to take oem filter out.
1 screw came easily but 2 others turn with allen key but dont go out.
Some of you already got this problem.If yes, how did you solve it?
Envoyé de mon SM-G955F en utilisant Tapatalk
Its possible that the two nuts that are embedded in the airbox spin with the bolt because the plastic has enlarged around them. My dealer used a electric screwdriver to spin the bolt and the nuts so that they would enlarge the hole even more. Pulled the plastic cover out by hand and used jbweld to reseat the nuts in the airbox.
Good luck
