Hi guys i was wondering if the air box mod is the same on the evo sp modle. I have never seen the lid of mine to find out if there is a hole in it or not
Same or very same, older airbox mods will still apply. Aloha Alex
if the exhauts are cored and the air box lid holed do you need to do anything to the ecu. Excuss my ignorance
With the stock ECU you can open the stock airbox up, & do a cat deleate, any more than that & you will start to run lean, so chances are you will have to get a PC or have your stock ECU reflashed.
Aloha Alex
Get it reflashed no matter what !! Open loop is a must with Siemens ecu's . She'll be smooth as silk at 3000 rpm and pull harder all the way to the blinking lights
