The Arrow header is less than $500. You won't need your LV cat elim/mid pipe. It uses stock mounting points and should work with your slip-on.my set up is Termi 2-1-2 in to spark flapper removal pipe, in to LV de-cat pipe, I just want an aftermarket header, does anyone make/supply such a pipe?
