Aftermarket fuel pump?
1708 Views 1 Reply 2 Participants Last post by  Shazaam
Hi Guys,
So i am trying to find the specs of the factory fuel pump so that i can replace it with and after market unit.
I am making a new tank and dont want to use the old unit.
Cheers
Adam
1 - 2 of 2 Posts
Flow rate 120 litres/hr (32 gal/hr). The fuel pressure regulator lifts at 3 bar (44 psi) so the replacement pump outlet pressure rating has to be in excess of this number.
Walbro makes the fuel pumps for many Ducati 4-valvers. Get the part number on the pump - either 5CA305-2 (white box) or 5CA305-3.
V. E. Peterson in Ohio (800-537-6212) will sell you an exact replacement pump for under $90. Ducati wants about $240.
1 - 2 of 2 Posts
