No.does the oil drain out of that area?
Easy fix... just blow a little air with your air gun in the banjo hole and piston will pop right out. Be careful! Too much air and piston will SHOOT out!The problem is that he pushed it all the way back in. I don't want to put it back on the bike so it is not a major issue, but just for future knowledge. I guess we learn from our mistakes...Only let the little bro help with washing, and waxing the bike from know on.
+ eleventy billion ... go easy with the air pressure, as you will have a large projectile coming out of the cylinder if your not carefulEasy fix... just blow a little air with your air gun in the banjo hole and piston will pop right out. Be careful! Too much air and piston will SHOOT out!
Goin' fer 25
