1 - 10 of 10 Posts
Hello all, im going to share how I successfully installed aftermarket fog lights on my 2019 multistrada 950s using stock ducati switch.
You will need a 4 pin relay, male 3 wire connector, other wiring supplies.
The ducati harness plug is located under tank on left side. It has 3 wires, red, yellow and black.
Red is power, yellow is the accessory trigger and black is ground.
Wire the Relay accordingly.
I used the same ground for lights and relay (black wire).
If you're running a pair of lights you will need to split the single ground and positive coming out of the Relay (1 wire becomes 2)
I ordered my 3 pin connector and relay from cycleterminal.com
I used shrink wrap, waterproof butt connectors and electrical tape to assemble.
This task takes some knowledge and skill.
once installed, the dealer will need to activate button.
Wood Electrical wiring Cable Electrical supply Wire
Gas Wood Wire Cable Metal
Tire Wheel Vehicle Automotive lighting Automotive tire
Font Slope Number Screenshot Darkness
Textile Gadget Font Material property Rectangle
Product Purple Rectangle Violet Pink
Automotive tire Automotive lighting Motor vehicle Automotive design Hood
2020, ducati 950s, Multistrada, wire spoke wheels
i have the ducati pdf for install.. does the tank and all the panels need to come off to access the factory pigtail on the left side of tank?
Discussion Starter · #10 ·
You definitely need the panels off, my plug was beneath the tank so I removed it. It is much easier for wiring and such with the tank off. You can clean your air filter while you're at it.
1 - 10 of 10 Posts
