I just did mine also on a 01' 748s.pveltri said:For those that have it installed, what is the clearance between the adjusting collar on the eccentric and the carrier (specifically the tapered bolt head that holds the sprocket to the carrier). I just put one on my 2001 748s and it clears but BARELY. I have maybe 0.02 inch, probably less. Did I install something wrong or is this right? Thanks.
Not sure what your talking about, are you talking about the tapered hex bolts that hold the sprocket to the carrier or the axel shaft bolt with the 41mm socket? The flare head bolts should be sitting in the recess on the QCC and basically flush with the QCC.
Don't forget there is a washer that sits between the back of the carrier and the axel shaft that rests on the bearing seal.
Can you take a picture?
-CC
